2 weeks ago
I’m travelling to Europe and just wanted to know if I am able to make a call in case of an emergency or if there is an add-on I can add for international minutes while travelling
2 weeks ago
Airalo is generally data only, no telephone calls or texts.
When I go to Europe I use an Orange Travel esim. It provides both data and a European telephone number, which allows you to have unlimited calls and texts in Europe. The plan also provides limited minutes to make international calls and texts back to Canada. For your friends and family to call you in Europe, they would have to dial long distance to that European number.
Generally, I set up WhatsApp on my phone so that I can communicate by calls or texts using data, either mobile or free Wi-Fi.
2 weeks ago
can you use same number if you get minutes through Airalo?
2 weeks ago
Definitely download and use AIRALO
2 weeks ago
@Alex73 , sorry public mobile does not work internationally. There is no added that you can purchase from them.
Have to go with third party such as Airalo sim card if you need ot connect to wifi.
