Travel to USA
georgyboy
Hello everyone,
I'm going to the states. In case of emergency, can I make a call to Canada and how much will cost me??? i use the prepaid service. Thank you
7 REPLIES 7
ghatanaka
For longer than 15 days consider a esim from AT&T or another US carrier that your phone supports
@georgyboy , yes, there's no usage limit over the duration of the add-on.  However, you should be warned that calling is only possible on the T-Mobile 2G network.  Calls are rather iffy based on community feedback.  I think if you were in a large metropolitan area, you are more likely to be okay.
@georgyboy  Yes you can for 15 days while in the US
georgyboy
The question is...
Once I buy the add-on $15 for 15, I can call Canada every day???
@georgyboy  Also note when purchasing US add on they start immediately so only purchase before your head off for your trip . Also you want to be connect to T mobile and possible reboot your phone  when in the US
@georgyboy - how long are you going for ? Roaming addon last 15 was days, and are active as soon as you purchase them, but only work in USA.
See what ones are available here:
https://selfserve.publicmobile.ca/en/account/manage/shop/addons
OR, you can dial 611 to purchase Roaming addons also from your public mobile device.
IF you are going for longer than 15 days consider a local SIM card.
@georgyboy  You need to buy a U.S. roaming add on to be able to
Adding sign into self serve go to plan add on tab and choose US add on that’s best for you
