Transferring number
Crowe
Transferred a number from old provider to public, received the sms from previous provider, confirmed that service no longer works, been over 5 hours and public mobile service has not activated sim, restarted phone.  Am i still needing to wait longer?
9 REPLIES 9
Crowe
Cs_agent have resolved the issue.  Thanks all for sharing thoughts
@Crowe
Then it sounds like a provisional issue with your SIM. Just private message a CS_Agent so they can fix it on their end.
Crowe
Yes
@Crowe
Did you confirm with YES to your previous carrier within the 90 minute window?
Crowe
Thanks, link worked, will update progress.....
@Crowe  you used wrong link
please use this particular link to message support:
Crowe
Cant make calls, text, and sim status all blank when checking about.....   attempts to create tickets goes error 100 page every time
@Crowe  Please message support to re provision the sim for you
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
@Crowe
so, you cannot even make outgoing calls?
try to reseat the sim card once and see if it works
if not, likely it is a sim provisioning issue, easy fix for PM, you just need to engage them via ticket, message them here:
