01-15-2024 05:30 PM - last edited on 01-15-2024 10:00 PM by computergeek541
I am having a problem getting connected with PM. I went through everything to set up the account. But, I’m not sure where the old SIM card should be. At first I left the old SIM card in the old phone and I put the PM SIM card in the new phone. Nothing happened. Now I have taken out the PM SIM card and still nothing has happened. Please help me.
01-15-2024 06:18 PM
Yes, I did get a text from my previous provider right away. I finally turned off my new cell and turned it back on and it is connected to PM now. Thanks for yr help
01-15-2024 06:16 PM
I did say yes, but, the problem was I put the new SIM card in the new phone too soon. I turned off my new phone and turned it back on and it is connected. Thanks for your help
01-15-2024 06:15 PM
It finally worked. I ended up turning off the new phone, and then turned it back on. Thanks for your reply
01-15-2024 05:37 PM
The OLD SIM card should be in any of the phones. If you plan to use the new one, then you should put it in that one. The important thing is that you have that old SIM in a phone that works. You need it to be able to get the confirmation text. Make sure you use the account number when doing the port. Once that's done and you replied then you can put the new SIM in your new phone or the phone you plan to use from now on. Re start the phone and try it out.
01-15-2024 05:32 PM
@Carman Did you not reply YES to confirmation text with old providers SIM card in phone ? No worries I’ll send you the porting team number private message and they can re trigger the port request for you
01-15-2024 05:32 PM
@Carman Have you initiated the port process from your PM account? Once you do that your old phone should get a text from your old provider asking if its OK to port out your number. Answer yes, and have a while the new phone with the PM phone will get a text saying the port is complete and to reboot your phone.
