Telus has the fastest wireless network in Canada, according to Ookla Speedtest
Good1
14 REPLIES 14
@RobertQc, source for what? DL speeds are within 1.5% now.
Effort
I saw this topic and I was like teehee, lemme try some speed tests again of 3G. Got 8Mbit down/ 2Mbit up. Good, I like using 3G.
Then I switch to 4G just to check ping and jitter, and then it spikes to 41Mbit down, and I force shutdown speed test. Public Mobile's throttling kinda sucks. Lol. I don't know how much that used, maybe like 50MB of data because butterfingers trying to close app.
@sheytoon wrote:
@RobertQc, the Open Signal results clearly showed Telus was faster 6 months ago. It seems Bell has made some improvements since then and they're back at being equal now.
Source?
@@sheytoon wrote:
The difference between Bell and Telus is splitting hairs. They're basically equal.
"Telus tops Bell and Rogers in LTE speed, says OpenSignal report" https://mobilesyrup.com/2018/02/07/canada-lte-connections-speed-increase-2017-opensignal-report/
@popping wrote:
@RobertQc
Someone said that the current 3G plan is throttled to 3Mbps if your phone is set at  LTE.  You get full 3G speed when you set your phone to 3G.
Does this effect latency? I was under the impression hooking up as 3G instead of LTE would put you on the older 3G WCDMA: 850/1900MHz setup.
@ShawnC13 wrote:
@RobertQc wrote:
Their network might be the fastest, but my 3G is throttled 😉 WTG Telus
Yes but that was your choice in plans you didn't need to choose it lol
Of course lol. I use less than 1mb per day so even 2G / GPRS / Edge / 1G would be ok. I didn't mean it in a bad way 🙂
sheytoon
@srlawren wrote:
@will13am wrote:
@popping wrote:
@RobertQc
Shhh.  Loose lips sinks ships.
@will13am this has been pretty widely dissemenated already.  I don't think this is going to increase the likelihood or timing of this loophole eventually becoming closed.
Why take the risk.  Who knows, this might be fixed before moving onto correcting the password reset function.  Go after the low hanging fruit first, lol.
srlawren
@will13am wrote:
@popping wrote:
@RobertQc
will13am
From my perspective, this is a great talking point for the marketing hype.  Practically, this means absolutely nothing to the average user.  Data usage continues to be the weak link in cellular plans.  Why do people need wireless data speed that is faster than most home internet plans to consume all of a few GB each month?
@popping wrote:
@RobertQc
@RobertQc wrote:
@Good1 wrote:
https://mobilesyrup.com/2018/08/01/telus-fastest-network-canada-ookla-speedtest-report/
Keep it up Telus! 🙂
popping
@RobertQc
RobertQc
Keep it up Telus! 🙂
(I know, I chose and pay for and am happy with 3G)
WTG Telus, keep up the good work
