Switching plan keeping rewards?
xtrawest
If I choose to switch will I loose all these rewards & discounts I have accumulated in last few years?
Rewards:
Loyalty- $5.00
Subscription- $2.00
Refer-a-Friend-$4.00
self solution removed/solution re-assigned
xtrawest
Alright done!! Thanks everyone for your replies!!Screenshot 2024-03-01 115854.png
TheSterlinger
You will keep your rewards. When you change plan press change on renewal so you don’t lose any rewards during the change.
