Switching from 90 day to 30 day plan
rodolfomartinez
Just wondering if anyone can answer this:
Currently I am on the 90 day 4GB plan.  If I switch to the 8GB 30 day plan, I am renewing every 30 days and my data does not roll over? Currently, I have 90 days to use 12gb, so I am guessing I will lose this ability, and will have to limit my usage to 8gb per month.
Is this correct, or is there a 90 day option for the currento $50 promo?
Shapla001
as the data is not an add-on, so no rolling over in 8GB plan
ShawnC13
My thought is that if you are planning to switch to 8GB/30 days the current 12GB for 90 days must not be enough.  With your new plan you are getting 24GB in 90 days now so double what you currently have.
will13am
@rodolfomartinez, this is one of the advantages of the 12GB/90 day plan.  Many of us are still on it and like it for the flexibility.  If you are able to manage your usage to 12GB over 90 days, perhaps reconsider the change.
popping
@rodolfomartinez
Correct.  The unused data on a 30 days plan will not roll over to next 30 days.  On the other hand, the data are shared within the 90 days period for the 90 days plan.
Dunkman
That is correct.  Your 8 GB will be only for one month and won't roll over.  There is no 90 day version of this promotion at the present time.
