12-22-2024 10:08 AM
12-22-2024 10:56 AM
@Johnny1948 wrote:The link doesn’t let me email customer support. It just gives me another menu of questions.
No, you were not using the link I posted, this is the link
it should open a message screen to CS agent
12-22-2024 10:50 AM
12-22-2024 10:48 AM
The link doesn’t let me private message customer support. It just gives me another menu of questions.
12-22-2024 10:40 AM
if you got an error at step 5 (Pprting number) or got an Subscription error at step 6, the subscription was never completed and calling porting team won't help. (another indication is that your PM sim should show "Sim not provisioned" or "SOS" on the status screen). You will need to message support instead of calling the porting team
Please private message CS Agent at:
12-22-2024 10:35 AM
HI @Johnny1948
but did you complete the porting step and did you get to the end of the activation step?
For porting, It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call
12-22-2024 10:28 AM
When I tried to port the number, it said that something went wrong. I still have my previous SIM card in my phone. The text from my previous carrier never came to port the number.
12-22-2024 10:20 AM - edited 12-22-2024 10:21 AM
HI @Johnny1948
you made the payment already but you said subscription no working. Did you already request porting?
12-22-2024 10:19 AM
K. I’ll try this.
12-22-2024 10:18 AM
@Johnny1948 So then with iPhone 8 you have new physical sim card for public mobile too. You can port number after you make payment but you need to activate the PM SIM card in the PM app not website
12-22-2024 10:17 AM - edited 12-22-2024 10:18 AM
Make sure PM sim is set as Primary and Turn on this line is enabled. And check if outbound calls work. If outbound does not work, then message support agent
But if outbound calls work and just not inbound , then it is just a porting problem
12-22-2024 10:14 AM
I have the Physical Sim card from my previous carrier, in my iPhone 8, to port my number.
12-22-2024 10:10 AM
hi @Johnny1948
what phone do you have?
esim or physical sim?
but first, make sure your old carrier sim card is removed, or if the old one is an esim, disable it
then reboot the phone and Reset network settings. Check if you can make outbound calls and if data work
if nothing work, and if have physical sim, you can test the sim in another phone
last, ask PM support agent to check if the setup was done properly on the system. You can submit ticket by direct message:
12-22-2024 10:10 AM
@Johnny1948 Have you rebooted the phone yet ? And physical sim it eSIM ?
