Subscription not activated. Please help
PublicMobUser88
I already paid, payment went through. Subscription not activated. When I click Get Support and then log in, I am stuck on a blank white page when a button "Done" on the top right hand corner.
I think the important question is...  does your phone accept eSIM? If not, you may require a physical SIM card. If you do need one, you can contact a local Telus store and see if they have any or you can purchase one off of Amazon. Just don't purchase directly from PM.
@PublicMobUser88
Try rebooting your device, resetting network connections, toggling airplane off/on.
Indeed, any one of the above options may work.
Try them all and see ...
PublicMobUser88
Yes through the app. I chose the eSIM option
mojorising
Are you doing the activation through the PM app? If not, you're going to need it to complete the activation.
