Spam via msg.koodomobile.com
dave705
I keep getting spam texts / MMS sent via [mynumber]@msg.koodomobile.com.
Can I block these?   I have an iPhone if that helps.
Thanks
@dave705   are you on Android?  If so, try switching the text app to Google Message instead of using the stock app, it works betting with blocking contacts.
dave705
The sender is already blocked but their messages still get through. Maybe because it is a group message to more than one person.
@dave705
Yes you can block any text by clicking on the name on top of the text>name of caller>info>scroll down to Block this Caller.
Meow
Yes, you can block it. If you do not recognize sender. PM sends SMS from 611 or 4 digits numbers.
@dave705   yes, you can.  Look like some spammer is using email to text fake the sender
rule of thumb, never click on link from text from those you don't know or you doubt
