Sonim-XP1520-BOLT-SL
etilaf
I want to know if this phone is compatible with Public mobile sim cards....
@etilaf at the moment the 3G EOL is expected  to be end of 2025, but it is not a firm date.  Many expect they will extend this further
if you have this phone already,  you can use it .  But if you need to buy it, avoid
@etilaf
The phone will be good to 2025…two more years before 3G will be decommissioned to make room for 5G.
There are good used phone from PM at reasonable prices.
@etilaf - I would look for something else to use with Public Mobile, if I were you.
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
https://willmyphonework.net/
darlicious
@etilaf
Yes but it only has 3G connectivity  so it will be obsolete soon and will not work at all in the US.
Edit:
OK it will work on T-Mobile's 2G network in the US.
@etilaf  Can check here
Phone / check for use on pm
