09-08-2021 04:45 PM - edited 01-06-2022 03:19 AM
Hi I need help .because my sim card is not working.it say's not sending messages with public mobile network.and it's not connecting to public mobile.thanks
09-09-2021 07:14 PM
@trexie wrote:It's my old sim and I'm using lg velvet
What do you mean 'old sim'? You cannot reuse a SIM that was used on an account/phone number that has been suspended for over 90 days.
Is the lg velvet a new phone to you? You Sure it is unlocked?
Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
Do services work in another phone?
09-08-2021 06:59 PM
@trexie wrote:Hi thanks for the time!.yah I'm a public mobile customer.i already tried removing the sim and restart my phone.even my network setting I restarted but still not sending and receiving messages and calls
do one thing Make sure your phone is off before removing your SIM card,
and take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
and if still not fix it please you Have To Submit a Ticket To Customer Support Agent by CS_Agent,
Explain your issue to Contact Customer Support Agent by CS_Agent ,
they can solve your issue, they are nice service Team the will help you 100%.
Here’s how to contact Customer Support Agent by CS_Agent,
Good Luck
09-08-2021 06:58 PM
09-08-2021 06:56 PM
09-08-2021 04:49 PM - edited 09-08-2021 04:52 PM
@trexie wrote:Hi I need help .because my sim card is not working.it say's not sending messages with public mobile network.and it's not connecting to public mobile.thanks
Are you a new customer? Is your phone unlocked? Have you reinserted the SIM card and rebooted? Can you try the sim in another unlocked phone.
09-08-2021 04:48 PM
are you get a new number or port old number, what your device model....
