Service not working
God1414
I can’t make or receive phone calls or text msg nothing is working
@God1414
I know there was an outage yesterday back east but check if there is one in your area:
https://istheservicedowncanada.com/status/telus/map
TheSterlinger
Are you using eSIM or a physical SIM card? If you are using a Physical SIM then try taking it out restarting the phone putting it back in and try.
If still it’s not working you can submit a ticket to a Public Mobile CS agent with the link below.
HI @God1414
you are new activation ? service ever work before?
try to reboot the phone, try to take sim out and put it back and test
and login using Incognito/Private/Secret mode on your browser to My Account and check if account is active
