Samsung Galaxy S8 compatibility
Kovacsa
Anyone have a Samsung Galaxy S8 phone? (SM-G950W)? Is it compatible on the PM network?  Thanks!
19 REPLIES 19
@Kovacsa  It doesn't necessarily follow that what gets VoLTE on Telus will also get it on PM. PM's VoLTE list is here, scroll down the page
https://www.publicmobile.ca/en/on/get-help/articles/volte
You can do a rough test here in Canada, turn off wifi, turn on cellular data, make a phone call.  If at the top of the screen it drops from LTE to 3G then you don't have VoLTE.
Kovacsa
Checked on Telus' site.  Would this mean I'm good to go with VoLTE wherever?
@hTideGnow   I don't know about T-Mobile but AT&T's VoLTE list appears limited to S8 models G950U and 950U1.
@Kovacsa  The phone needs to be VoLTE (voice over LTE) capable and enabled otherwise it will try to make calls over 3G which no longer exists in the USA.  It can be a 4G/LTE phone but not be VoLTE capable or carrier enabled.  I have one such myself that was on Rogers and I got the notice from them that it would no longer work for roaming in the US.
HI @Kovacsa
yes, your phone is 4G and will work data without problem
question is VoLTE or not
the phone is not VoLTE compatible with PM but it has VoLTE and it is compatble with T-Mobile and AT&T.  Some believe it will still not work VoLTE when you roam.  But my friends work in the industry said while it won't work VoLTE in Canada with PM, it will work VoLTE with T-Moble or AT&T.
But either way, it will just affect voice when you roam, data will work
Kovacsa
It's always a possibility that I could go to the US.  I have a 4G phone though, not 3G, shouldn't I be okay for roaming should I need it with a 4G phone?
So yes the latest version is 9.
My S20 is currently on 13, that was the mix up👍
Phil_Adelphus
@Kovacsa   Are you likely to visit the USA?  A non-VoLTE phone will not work well when roaming there because of the shutdown of 3G networks, you would have to connect to T-Mobile's 2G where available.  Not an issue in Canada because we still have 3G here for now.
HI @Kovacsa
typo, and fixed now
i meant it wont have VoLTE.
yes, s8 works LTE and 4G without problem
I'm sure that's correct. I'm probably thinking of something else.   I'll check the phone again later.👍
Kovacsa
What do you mean it won't have LTE?  I have 4G LTE+ now with my current carrier, why wouldn't it work with PM?
HI @Kovacsa
yes, S8 won't have Android 13 because it is too old the phone
However, for use on PM network, it works perfect without issue.  You can also download PM app using S8 with Anrdoid 9
@Sansan
Updates on Androids is only about 3 years so the latest OS will be android 9 on this phone in 2000.
Kovacsa
SGS8 doesn't support Android 13, only up to Android 9
Last update is android 13. Won't update anymore,  but we have had no issues day to day usage.
@Kovacsa
Yes, I have the Samsung S8+ and the Samsung S9…no issues at all.
HI @Kovacsa
Yes, Galaxy S8 will work beautifully on PM, both data and voice
just that it won't have VoLTE, but it will still work great
Sansan
We have this phone and we have service with public mobile. No issues with it
Dunkman
@Kovacsa
This phone is compatible with Public mobile.  It will unlikely be compatible with VoLTE service though.
Here are the specs of this phone:
https://www.gsmarena.com/samsung_galaxy_s8-8161.php#g950w
Here is some more info:
https://www.publicmobile.ca/en/ab/get-help/articles/check-your-phones-compatibility
