SIM replacement
gb2k
If I lost a SIM card, would it be possible to replace it and keep the same phone number?
If so, can someone tell me how I'd be able to do that?
2 REPLIES 2
Dunkman
@gb2k
Here is a help article on changing SIM cards:
https://www.publicmobile.ca/en/ab/get-help/articles/change-sim-number
@gb2k   Yes . Just Get new SIM card from Koodo or telus call around first for  availability or order from Amazon . Then with SIM card In hand .In you account profile page you can SIM card swap the number to keep phone number and plan the same like this
SIM  SWAPPING  profile tabs
Note only do this on lap top or computer/ not mobile device
