SIM card not working
DK3
Payments up to date.
It says I am not connected to a mobile network even though my sim card is inserted.
Have tried restarting phone and reinserting sim card.
 When I try to send a text it says:  "You may be able to send after inserting a sim card" but
there is a sim card inserted.
18 REPLIES 18
cmobile
I have a iphone 5s which showed NO SIM occasionally.  One day I did a reset on "network setting" and all problem resolved. Give it a try.
DK3
This worked! Thank you
@DK3
try this solution
Try going in to settings and search for carrier. Tap on the setting and it should take you to the menu to add a sim.
maybe the recent April security update corrupted your software.
@DK3
I would suggest you bring the phone into the place where you picked up the phone. If it is defective, it might be still under warranty.
@DK3
ALSO, make certain you're using the correct size SIM card in the SIM tray - you may need an adapter to assist in it's orientation within the slot.
There's also a possibility using a small piece of paper on the NON-CONTACT side may help to enhance the contacts on the SIM to the device.
Be careful.
@DK3
Try these steps (depending on what you have around), to clean a SIM card:
Use an eraser or cotton swab to remove dirt or dust. Gently rub the eraser or cotton swab along the gold contacts on your SIM card. Continue to make light strokes until your SIM card is clean.
Wipe the card with a dry, lint-free cloth for all-over cleaning. Simply wipe down your SIM card using a clean cloth. Don’t apply any cleaners to the card or the cloth. This can remove dirt, oils, and moisture from any part of the SIM card.  A microfiber cloth works well for cleaning any part of your phone, including the SIM card. Dry cloths made for eyeglasses are a convenient option.
Use rubbing alcohol to remove oxidation.  Dampen one end of a cotton swab with rubbing alcohol. Then gently rub the alcohol against the gold contacts on your SIM card. Continue cleaning the contacts until all of the oxidation is gone. The cotton swab should be damp but not soaking wet with alcohol. Do not get any rubbing alcohol inside your phone
@DK3 , did you try network reset?
Swipe up to view the apps.
Touch Settings
Scroll to and touch System
Touch Advanced
Touch Reset Options
Touch Reset Wi-fi, mobile & Bluetooth
Touch Reset Settings
Touch Reset Settings again
It should the reset the network settings
LEGO
benfatto
@DK3 "My sim card did work in her phone. So that means the issue is with the phone? "
pretty much; hopefully a pixel expert will stop by. Guess you could try a factory reset.
DK3
OK thank you for your help
 @DK3 : Yup. That's how to narrow down where the problem might be.
DK3
The SIM card has been working fine up until today when it randomly stopped working. I tried using my daughter's sim card in my phone and it didn't work. My sim card did work in her phone. So that means the issue is with the phone?
Thanks
 @DK3 : Take out the SIM and clean anything off the contact surfaces. Could be some oxidation or dust or something. Can you try a different SIM in the phone? Like a friend or family.
Make sure the SIM is the correct size. Maybe it finally got dislodged from a fluke position. It should fit evenly and flush on a tray or snugly into a slot.
Triguy
You can wipe the sim with a clean soft cloth.  Are the gold contacts facing down or up ?
DK3
Yes I am able to login and it says my plan is Active. I have a google pixel 4a.
DK3
Thanks for your response.
No other phone.
How do I clean contacts?
Pixel 4a
 @DK3 : Do you have another phone to try the SIM in? Can you login to your self-serve?
Triguy
If you have another phone then try swapping it.  Also try cleaning the contact points then reinsert the sim.  Which brand and model of phone do you have ?
