Rewards system
obd
I'm on the old reward system with an autopay, loyalty discount, and refer-a-friend discounts. If I change plans do I get to maintain this reward structure?
obd
Thank you for your quick replies.
@obd  Yes you will keep your old rewards I can confirm I just switched  plans and kept my old rewards have a peek
JRod
@obd
Loyalty rewards are tied to your account so you will keep them as long as you don’t manually opt into the new rewards system. Changing your plan will not effect your old loyalty rewards and you’ll continue to earn them as you were on your previous plan.
Your refer a friend rewards are also account bound and will not be affected by a plan change. Everything for you will stay the same.
