05-26-2022 01:16 PM - last edited on 05-26-2022 04:07 PM by computergeek541
05-26-2022 02:18 PM
If it just happened to should be able to manually change you to 25 plan and put the other 25 in your account balance so it will cover your next renewal and you won't have your card charged again until late July
05-26-2022 02:14 PM
If you opened your account just now - today, contact agent asap so they can change plan for you.
If they cannot assist you for whatever reason, go and schedule plan change on next renewal and downgrade it to $25. You will have to enjoy benefits of $50 plan for 30 days and then go back to what you wanted.
Good luck and let us know if agent was able to help you!
05-26-2022 01:56 PM
HI @RA8 it is possible that CS Agent will help. but they might only put the extra fund back to Available Fund and not an refund.
Please open ticket with CS Agent at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
05-26-2022 01:24 PM
Did you literally just activate? Try contacting customer support and ask if they will put you on the $25 plan and credit your account. It can't hurt to ask but there are no guarantees.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-26-2022 01:21 PM - edited 05-26-2022 01:22 PM
hi you will need to open a ticket through Simon to speak to an customer service agent they will help you mention overpayment issue
