2 weeks ago
Hello, I am planning to switch over to Public Mobile with a new offer for a 5G eSIM. However I would like to retain my current phone number. Is there a way to do that? Thanks.
2 weeks ago
@WENth100 most numbers can be ported into PM but not all. Check it first here (it is a Koodo site but both Koodo and PM are owned by Telus and use the same network)
https://secure.koodomobile.com/checktransfereligibilityparrot/checkSingle.do
Once confirmed the number can be ported, download PM app and start the activation using the app. Remember to get a friend code to activate and
2 weeks ago
Yes, you may do that. You must keep your current phone provider's service active and you must submit a port request from your current provider. You must create an account and select a plan and select transfer number. Download Public Mobile App to active your service.
