03-03-2023 12:34 PM
I'm not getting an email verification code when I go to reset password. SIMon says email can take upto an hour, but that's lame as you only get 90 seconds to put it in
03-03-2023 02:21 PM
Did you lose your sim or phone? The sms option works for password reset.
03-03-2023 12:39 PM
Hi @Stephen8 you sure you have the correct email address for My Account? Check spam folder
For reset password, I believe you can also have the code sent to your phone instead. Try it
If that does not help, please submit a ticket to CS agent
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
03-03-2023 12:35 PM
@Stephen8 have you check your spam folder to be sure?
if nothing came, then please open ticket with PM support for reset password assistance
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
