02-22-2022 03:29 PM
Hi Public mobility
I want to know that add-ons.
I'm planning to change my plans.
But I have some purchased, holidays, and one-time add-ons.
Will that add-ons stay at my account so I can use after I change the plan?
Or the Add-ons will disappear because I change the plan?
Thanks
02-23-2022 05:44 AM
It was smart of you to come to the community to ask your question and not trust what a clerk thinks the answer might be....the community often knows more than pm employees do! Purchased and gifted add ons stay on your account until completely consumed.
Promotional bonus add ons when activating often have condition that they will be lost if your rate plan is changed. This is almost always true if it is bonus recurring plan data but bonus data add ons are retained on the account 99% of the time. ( I haven't lost one yet!)
To pre-verify your account include your full name, address, email, phone # and 4 digit acct pin #
02-22-2022 04:41 PM - edited 02-22-2022 04:42 PM
@chloe70 That may just be a generic message that gets displayed as some sign up promos have conditions whereby changing plans may lose bonus data but it does not apply to either purchased or gifted add ons. So you can safely change plans but are advised to schedule the change for next renewal.
02-22-2022 04:39 PM
HI @chloe70 The good thing for PM is that Add-on has no expiry date and won't got removed even if you change plan. So, the only way you "loss" the add-on is that you are done using it or you leave PM 🙂
02-22-2022 04:38 PM
But when I tried to change plans at next renewal, the confirmed message said I will loose all remain Add-ons. Also when I asked Clark of in-store where I opened public mobile line, he said I will loose every Add-ons because of the public mobile's technical issue.
02-22-2022 03:37 PM - edited 02-22-2022 03:37 PM
02-22-2022 03:33 PM - edited 02-22-2022 03:35 PM
@chloe70 Purchased or gifted add-ons (excluding roaming add-ons) will stay with your account until they're depleted and will not be affected by any plan changes.
Edit: BTW, it's usually recommended to change plans at next renewal rather than immediately as PM doesn't prorate or refund unused features of your current plan.
