08-28-2020 09:52 PM - edited 01-05-2022 12:58 PM
If I use a referral code and deactivate will the referrer's $1 discount be reinstated when I reactivate?
08-29-2020 05:14 AM
Once your account goes into suspension your referrer will recieve a text : Public Mobile here. "Just to let you know your Refer a friend reward will be less on your next payment due to one of your friend's account inactivity." Your friend will see $1 less in their rewards in their account.
Once you renew your referrer will recieve a text: "Cha-ching! You've successfully referred a friend to Public Mobile, way to go! To view your current rewards, visit https://bit.ly/3444'akfm. (sic)
Your friend will then see $1 added to their reward section in their account. There is no 30 day waiting period it happens almost instantly.
08-28-2020 09:53 PM - edited 08-28-2020 09:58 PM
@martik777 wrote:If I use a referral code and deactivate will the referrer's $1 discount be reinstated when I reactivate?
It'll be reinstated a month after (30 days) you reactivate your account.
PS..the referee might have to remind the moderator to re-add the reward.
