2 weeks ago
I’m trying to transfer my phone number from Freedom mobile to Public Mobile and I accidentally deleted my Freedom mobile eSIM before the transfer was complete so I wasn’t able to authorize the text message.. Freedom told me all I have to do is contact Public Mobile and have them re-initiate the transfer, but I can’t get a hold of anybody
2 weeks ago
HI @Paulv999999
i sent you. Check again using this link
2 weeks ago
Ok thank you
2 weeks ago
HI @Paulv999999
Koodo and PM both owned by Telus and Koodo porting team helps PM for porting issue. So, it is the same number. You should have the number I sent you too
2 weeks ago
Hi I’m sorry I haven’t gotten anything
2 weeks ago
That’s Koodo not freedom mobile …. I need public mobile to send freedom mobile the transfer request
2 weeks ago
HI @Paulv999999
if Freedom said it is ready for PM to reinitiate the porting request, then you just need to call porting support team
I have sent you the porting support team number. Please check your Community inbox (envelope on top right), check for the number and call
2 weeks ago
@Paulv999999 , you should be able to call the porting team number in the link below and they can rescue the port for you.
