08-15-2016 10:42 AM - edited 01-04-2022 03:02 PM
08-15-2016 02:16 PM
Hey @Amanda which thread would like us to follow trying to help you?
I thought you said it never worked since July 8?
08-15-2016 02:14 PM
08-15-2016 02:06 PM
08-15-2016 01:54 PM
@Amanda Since you can connect to wifi, try an application like that from fongo.com. It provides free calling across Canada from wherever you are connected to wifi. You can at least coonect by phone with key people until PM service is sorted.
08-15-2016 01:46 PM
@Amanda If you can make calls but not receive them then you have indadvertently blocked calls; either from iPhone settings or with an app. Look at Settings >> Phone >> Blocked.
08-15-2016 01:42 PM - edited 08-15-2016 01:43 PM
Sorry to hear about your troubles.
Outgoing calls are fine but you are not recieving incoming calls? Are the recieving calls going directly to voicemail?
Have you tried the following settings on your iphone:
As much as I hate to say it the last resort would be restore your phone but unless you are willing to lose all your data, I would not attempt unless you regularily backup your mobile device to either itunes or icloud. It seems that PM is investigating so let's see what PM responds back with.
PS, I too have lost a few loved ones this year and the list seems to get longer as we age. Unfortunately things tend to get worse when we are already down. I'm more than confident that PM is doing what they can to resolve your issue as quickly as possible.
		08-15-2016
		01:33 PM
		08-15-2016
		01:34 PM
			Shazia_K
************* or text or FaceTime audio *************please
08-15-2016 01:29 PM
Can you please allow at least 24 hours? I will send a ticket to our support team someone will get in touch with you in about 24 hours, can you please send me an alternate phone number where we can reach you?
Please send it to me via private message.
Thanks,
Shazia
08-15-2016 01:29 PM
08-15-2016 01:27 PM
08-15-2016 01:27 PM
08-15-2016 01:26 PM
08-15-2016 01:22 PM
Hey Amanda,
I need to clarify something, you have service which is available to you, you are able to use and surf your Internet, send and receive text messages, as for the calls, you need to verify the phone that you are using there is an issue that's coming from your phone and we can see it in our system.
We are able to see that you were able to use your calling service with another phone then the current one you are using, can you confirm this?
Can you please try your SIM card in another unlocked device?
We are trying to help you at the best we can.
Thanks,
Shazia
08-15-2016 01:17 PM
08-15-2016 12:58 PM
08-15-2016 12:51 PM
Hi @Luddite!
Mary talked to Amanda on Saturday and gave refund she requested. Here is a link to the thread: http://productioncommunity.publicmobile.ca/t5/Discussions/I-want-my-money-refunded/m-p/64677#M16306
@Amanda, please clarify if your refund was meant to terminate service or just a goodwill gesture from Mary?
If you wish to stay with PM, I am confident that Mary or Shazia can set up a new fully functional line for you, as long as you still have one active or unused sim card
08-15-2016 12:16 PM - edited 08-15-2016 12:16 PM
I can see Shazia is not currently on line. It's going to take a bit of time so I'd go on with your day and check back from time to time. We'll tag @Mary_M in case she comes in.
I suspect your problems all stem from using an inactivated sim. We'll see.
08-15-2016 12:13 PM
08-15-2016 12:08 PM
08-15-2016 12:08 PM
@Shazia_K Can reset your account password; watch for her private messages. In fact, send her a private message with your phone number and your new sim card number. Do you know how to do that?
You new sim won't function until you activate it in your account.
08-15-2016 12:04 PM
08-15-2016 12:03 PM
08-15-2016 11:59 AM
@Shazia_K If her 5c worked on PM, are you sure her account is properly configured and active?
@Amanda Did you simply move your PM sim from the 5c to the 5s?
Never heard of your problem. If you can try a sim from a friend that would confirm whether it's a phone or account issue.
Sorry, can't be more help.
08-15-2016 11:50 AM
If you are willing to try a new number, just log into your self serve account and look for "Change My Number". While in your account make sure it says "Active" and the plan is correct.
There is definitely something weird here.
08-15-2016 11:50 AM
08-15-2016 11:49 AM
08-15-2016 11:46 AM
08-15-2016 11:45 AM
08-15-2016 11:43 AM
08-15-2016 11:43 AM
Are you sure they are unlocked?
Are you transferring a phone number from another carrier?
Have you tried all of the suggestions from Shazia and me?
