Referral
Kimulya
I forgot to use my referral code, how can I put it now? Transfer is almost complete
7 REPLIES 7
Karl9
Hi, I'm trying to apply the referral code I received but I missed it upon activation. Can someone please apply it to my account? Thanks
Kimulya
Thank you very much
@Kimulya  They should reply with in the hour , just keep an eye on your community in box for their response, or you can use this link to the inbox
Kimulya
Thank you for the link, I messaged them.
Kimulya
Trying to contact and unsuccessful, so far. Thank you
R4mbo
You might want to ask for support if they are able to input your referral in the system.
@Kimulya  You need to ask support if they can apply it for you after the fact
send a  private message   To CS_Agents click
