06-28-2023 06:26 PM
@CS_Agent in our Community The referral discount I should get for having a friend sign up with my referral code is no longer active, they are still using Public Mobile
06-28-2023 06:34 PM
are you on the legacy rewards system? If you are , check the Friends list from the rewards site and see if your friend's number there.
If you're are Public Points, it won't show you the friends' number list, but it will show the total number of friends, is the total correct?
06-28-2023 06:27 PM - edited 06-28-2023 06:28 PM
@JA8 Did their account suspend . Did you change plans immediately and not on renewal . If no to both questions.then please message support
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
