Referral credit not showing up on the account
Olilee2023
Where would I be able to see the $10 referral credit on my account? I just signed up and received the referral code from my friend. I entered the code during my sign up process as well.
If you just signed up today @Olilee2023 , the Cha-ching text (as I recall) comes the next day around 1-2pm Eastern Time.
But has the customer you used their referral code checked their My Rewards section? There, they should see your last 4 digits of your phone number listed under the Refer a Friend area.
Olilee2023
They have not received the text yet.
@Olilee2023
Check with your friend if they got a text indicating “Cha-ching! You just added to your Refer a Friend Reward-way to go! Keep referring to earn more. View your Reward”.
If they did, you will see it in your account in 3 days but they should receive the $1/1 point credit in their account.
@Olilee2023  Can take up to 72 hours after activation to be in your available funds . Your friend that referred you should already see their $1 / 1 point right away . Can you can firm with them they got their reward . That’s a good indication it’s on its way and code  was entered correctly
@Olilee2023 - the $10 amount can take up to 72 hours to show up in your available funds area. If it goes past that point you can submit a ticket to CSA to tell them the code you used and ask them to add it for you.
