09-20-2022 05:18 PM - last edited on 09-20-2022 09:34 PM by computergeek541
Hello, my friend just signed up for Public Mobile on August 9, 2022 and used my referral code. I did not get any notification and could not find it in my account. How can I get it?
Please help
09-20-2022 05:23 PM - edited 09-20-2022 05:23 PM
@Smagnaye hi if you don't see the 1 dollar referral in the rewards section of your account or they don't see the 10 dollars then they need to
contact customer service to find out why
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or private message them here
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
09-20-2022 05:21 PM - edited 09-20-2022 05:22 PM
Hi @Smagnaye your friend should see the $10 in My Account within 72 hours. For you, you see see it on My Rewards Friend list within 1 or 2 days
If any problem, ask your friend to open 1 ticket with CS Agent for both of you
to open ticket with CS Agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
09-20-2022 05:20 PM - edited 09-20-2022 05:21 PM
your friend need to open ticket with PM support and ask them to check it out
At https://publicmobile.ca/chatbot.
Start by typing "Submit a ticket", then click "Contact Us", Then click "Other", then click "Click here to submit a ticket
have trouble with Chatbot: Private message CS Agent at:
