@Refer a friend
Mel121
How to connect a refer a friend code to an account that is now activated but wasn’t before.
2 REPLIES 2
HI @Mel121
if you missed a friend code when you activate, support agent can help to add it back for you.  please submit a ticket with CS Agent here:
The new account should see the $10 in Available Funds after agent added it back. The one referred will see the extra friend on Rewards site within a week later
@Mel121  You need to ask support to apply if for you
send  a  private message   To CS_Agents
