Reduce number of rings before voicemail kicks in
Derek345
Samsung Galaxy S9. I'm new to cell phones in general. Dinosaur.
Yummy
Just make some nice tune as 'ring' that will put a smile on your face and let it Ring, baby!
Derek345
Ok, thanks for saving me the trouble of further investigation.
@Derek345
Galaxy S9 is not a compatible VoLTE deivce on PM network at the moment.   So, you won't be able to set the number of rings as the Conditional forwarding is currently broken.  😞
Derek345
Galaxy S9. Already tried the above without success.
@Derek345
You can try  to do the following but likely you won't be able to do it now as the Coditional forwarding has not been working since VoLTE was introdcued
Dial this sequence: *61 *16475804001*11 *[then enter number of seconds to wait] # [SEND or CALL].
For the number of seconds to wait - choose from the following options:
For one ring, enter 5.
For two rings, enter 10.
For three rings, enter 15.
For four rings, enter 20.
For five rings, enter 25.
For six rings, enter 30 (This is the maximum number of rings/seconds).
SAMPLE: *61*16475804001*11*20#[SEND or CALL] - sets your phone to ring four times (20 seconds) before going to your voicemail. Best to check mailbox.
( also technically, dialing *61*16475804001*11*20# can be shortened to *61*16475804001**20# since voice service is assumed)
If that does not work, then yes, you are one of us without Coditional forwarding
But someone said it might be resolvable if your phone is using VoLTE instead of 3G for voice. First, what phone do  you have? that would determine if you can use VoLTE or not
