Receiving calls
Donje
why can’t I answer electronic call backs
Hi @Donje ,
Does this just happen with one company?
Can you have someone else try it to see if it happens to them as well?
kb_mv
@Donje wrote:
It’s when you are put on hold by a company and they give you the option of calling you back instead of you sitting on hold for an hour or so. You call back is done electronically instead of a person dialing it
@Donje Gotcha. So the company calls you back, you answer and there is nothing there? I would think this is an issue with the company calling you. I haven't heard of this issue with PM before. Hopefully someone with more tech knowledge will chime in here if it has happened.
Donje
kb_mv
@Donje What's an electronic call back? What do you do to try and answer it and what happens?
