Received call charge mins?
syantixmanjah
Really?! Only received incoming call you charge my minutes plan?
Don't get me wrong because I choose the smallest plan, because I'm new migrate to Public Mobile that I thought incoming call is not charge my minutes plan.IMG_20180901_185303.jpg
popping
@syantixmanjah
Per @will13am suggestion to get minutes add-on, the minutes add-ons does not expired.  Unused add-on minutes will roll over to next 30 days until they are used.  The minutes are not expensive - 4 cents/minute.  It is one of the cheapest Canada wide add-on minutes,
will13am
@syantixmanjah, fortunately Public Mobile offers calling add-ons that are industry leading in terms of cost.  You can buy some extra minutes just in case you run out and won't be able to receive calls.
syantixmanjah
Thanks for the reply @popping, I might be wrong because I saw it not carefully.
popping
@syantixmanjah
The $10 plan has 50 Canada wide minutes.  It does not say free incoming minutes .  Only the free incoming text messages.
https://www.publicmobile.ca/en/on/plans/10for50talk50text
