Receive and send calls
Doreenb
Not able to send receive calls for 2 days
7 REPLIES 7
@Doreenb wrote:
Where do I find the link
HI @Doreenb   no need to find link  here you are to contact CS Agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
Doreenb
@Doreenb
in above a link contact to support
Doreenb
Yes it dose the same thing in other phone
@Doreenb
do you take SIM card out and put it back or tried in other phone.
Doreenb
Had this # for 3 years
Timer
@Doreenb
do you getting new number or port your old number in here,
or contact to support team by  CS_Agent
