09-03-2021 07:28 PM - edited 01-06-2022 03:23 AM
I just purchased this plan for my daughter. She is unable to receive incoming calls? The plan said unlimited Canada-wide minutes which I gather includes incoming and outgoing calls?
09-03-2021 10:12 PM
@VictoriaM09 wrote:I just purchased this plan for my daughter. She is unable to receive incoming calls? The plan said unlimited Canada-wide minutes which I gather includes incoming and outgoing calls?
Hello @VictoriaM09
IS this an iphone?
Set up your phone number On your iPhone:
09-03-2021 10:11 PM
@VictoriaM09 wrote:Just charging another phone. If it works in that phone, does it mean the phone is the issue? If it still doesn’t, is it the SIM card??? So frustrated!!!
Yes, please let us know.
09-03-2021 10:10 PM
Yes, you can use another phone to test. If it works, then your original phone has some issue. If it does not work still, then likely SIM provisioning on PM side is the issue.
you just changed a new number? It should work quick, probably within an hour.
09-03-2021 10:04 PM
09-03-2021 10:02 PM
I picked a new number. We thought maybe it was a faulty number so I chose another one. Now it says the number is not in service. Hoping there’s just a delay? Now I’m being told the number isn’t in service.
09-03-2021 10:00 PM
@VictoriaM09 someone asked before and I am not sure you answer the question yet
did you port number from your old provider? or did you just picked new number?
09-03-2021 09:49 PM
@VictoriaM09 wrote:Thanks. But didn’t work 😔
Can you try the SIM card in another phone?
09-03-2021 09:45 PM
09-03-2021 09:45 PM
Didn’t work 😔
09-03-2021 09:44 PM
Nothing has worked 😔
09-03-2021 08:43 PM
Yes the $25 is unlimited incoming/outgoing calls.
You will need to reboot your phone so all calls will work.
Just power off the phone and wait a few minutes then power the phone back on.
09-03-2021 07:32 PM - edited 09-03-2021 07:33 PM
yes is it unlimited minutes include incoming and outgoing calls,,
do one thing Make sure your phone is off before removing your SIM card,
and do rebooting your phone take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
09-03-2021 07:31 PM - edited 09-03-2021 07:36 PM
Is this a new number or did you port a number over?
If this is a new number try the following:
1. Restart your phone to see if it will work.
If not then:
2. Set preferred network to 3G and restart phone.
If not then:
3. Reset network settings and restart your phone.
