09-03-2021 07:28 PM - edited 01-06-2022 03:23 AM
I just purchased this plan for my daughter. She is unable to receive incoming calls? The plan said unlimited Canada-wide minutes which I gather includes incoming and outgoing calls?
09-03-2021 10:04 PM
Just charging another phone. If it works in that phone, does it mean the phone is the issue? If it still doesn’t, is it the SIM card??? So frustrated!!!
09-03-2021 10:10 PM
@VictoriaM09 wrote:Just charging another phone. If it works in that phone, does it mean the phone is the issue? If it still doesn’t, is it the SIM card??? So frustrated!!!
Yes, you can use another phone to test. If it works, then your original phone has some issue. If it does not work still, then likely SIM provisioning on PM side is the issue.
you just changed a new number? It should work quick, probably within an hour.
09-03-2021 10:11 PM
Yes, please let us know.
09-03-2021 10:12 PM
@VictoriaM09 wrote:I just purchased this plan for my daughter. She is unable to receive incoming calls? The plan said unlimited Canada-wide minutes which I gather includes incoming and outgoing calls?
Hello @VictoriaM09
IS this an iphone?
Set up your phone number On your iPhone:
09-03-2021 10:13 PM
So true the SIM card in another problem. Still getting the message that the number is not in service. At least it’s different than the message I got prior to changing the number!
I’m going to try again in the morning.
thanks everyone!
09-03-2021 10:15 PM
@VictoriaM09 I guess it is time to open a ticket with PM ..
(After you open a ticket with Customer Support Agent, please monitor your Community inbox, envelope on the top right. Customer Support Agent will communicate with you via messaging within Community)
1. For faster response (2 to 48 hours), Click on the bubble in the lower right corner and request Cusstomer Support Agent assistance, or you can also use this direct link instead https://publicmobile.ca/chatbot. Start with typing "Submit a ticket", click on "Contact Us", click on "Other" from the choices, click "Click here to submit a ticket" then Follow the prompts to submit a ticket.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
09-03-2021 10:15 PM
I’m new to this, so not sure if a reply goes to the individual or if everyone on the string can see it?
SIM card on a different phone resulted in the same message, that the number is not in service. Here’s hoping it just takes time!
I’ll write again in the morning. Thanks everyone!
09-03-2021 10:16 PM
Thanks! I’ve been corresponding with an agent as well. Still no luck!!!
I appreciate the link. I’ll keep that handy!
09-03-2021 10:17 PM
@VictoriaM09 wrote:So true the SIM card in another problem. Still getting the message that the number is not in service. At least it’s different than the message I got prior to changing the number!
thanks everyone!
IF you are not committed to that phone number, you could try changing the phone number through your Self Serve account to see if that triggers your account to work.
You can change your number 4 times every 30 days, if you wanted to.
Are all the other services working?
09-03-2021 10:28 PM
Yes, this is an iPhone. Thanks for clarifying!
The old phone number was still listed as the number for receiving messages. It’s taking forever to verify the new number! Maybe because it still isn’t active? I’ll do the FaceTime step next.
Thank you!
