Re: Disabling voicemail
topsy
I used the above procedure some time ago and it worked fine. Now I wish to go back to normal voice mail and went through procedure  and it seems to work but no actual voicemail is recorded
@topsy wrote:
When I try to retrieve voicemail messages using another phone after I enter the phone number it only seems to allow me to leave a message not to retrieve messages
@topsy , call your phone number from another phone, once the recording begins push the star ( * ) key.
topsy
@topsy
yes, checking voicemail from another line is always free  🙂
topsy
Thanks softtech. Can I still retrieve voicemails without getting charged by dialing in to voicemail number from a different phone?
@topsy
To reset all of your call forwarding to default (voicemail) dial ##004#.
