01-15-2024 11:29 AM - last edited on 01-15-2024 10:18 PM by computergeek541
I would like to know if my DATA is working now. I have shifted the number from VoIP number to here, Public recently. As of now, I don't see any indication that I have data.
01-15-2024 10:19 PM - edited 01-15-2024 10:21 PM
@Handy1 wrote:@ELJAN Put the PM SIM card in the phone and reboot the device and test for services calling texting and data I can also send you the porting team number private message for status update on the port . You. An also re trigger the port request if needed also
Data services are unrelated to number porting issues.
01-15-2024 12:04 PM
@ELJAN Please submit ticket with support to investigate
send a private message To CS_Agents
01-15-2024 12:00 PM
Try disable WiFi and see if you can use data.
One way to check on your data usage is to login to your account in the PM app or online and it will show on Overview of your account.
01-15-2024 11:56 AM
I don't have a Physical Simcard but E-sim. I have rebooted my phone but I still don't see the 3G/LTE indication that I do have a data.
01-15-2024 11:33 AM
