2 weeks ago - last edited 2 weeks ago by computergeek541
I am currently have a plan with fido but I am planning to move into PM. I just found out my plan was a tablet plan and it did not have any ability to text or call. I was wondering if it was possible to still port this tablet plan to PM and turn it into a phone plan. If I can, I might not be able to receive the text message confirmation for porting as I mentioned my current plan has no text. What can I do about that?
2 weeks ago
2 weeks ago
@EJ37 You can try the number in this Koodo number eligibility test. If it is OK with Koodo then there's a reasonable chance it will port to PM.
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
2 weeks ago
I never said I wanted a PM tablet plan
2 weeks ago
PM doesn’t have plans for tablets but check with an agent to confirm. Click on Chat icon and type in Submit a Ticket.
2 weeks ago
correct
2 weeks ago
@EJ37 The tablet plan gives you a phone number but can't call or text?
2 weeks ago
hi @EJ37 from what I. understand, if you create a Fido tablet plan and g9t that number via that plan, you might not be able to port out that number. Check with Fido support, it is thier call and not PM
