Porting a number
shurixp
Hello! I am trying to port a number from Public Mobile to Shaw, and the Shaw agent asked me to contact Public Mobile and let them know to accept the request manually. Would anyone be able to assist me with that?
12 REPLIES 12
LegusY
Contact a support agent and he/she will be able to approve the request usually, the normal procedure is to keep the old sim (PM) and wait until you see a SMS for port out request which you have to reply "YES". But in this case, something might be messed up, then make sure you contact PM support agent within 3 hours of port request from Shaw, within that time frame, an agent from PM will be able to approve it. If 3 hours have passed, the request will be expired and you have to send a new one from Shaw and contact PM again within 3 hours.
shurixp
I appreciate it! Thank you!
@shurixp   your best friend is a VoIP app, you can download it and call yourself on the app just like a real phone
try Fongo or Textnow
but in your case, it is clear that the porting has not been completed yet because you can still login to PM My Account.    If you replied YES, I would not be too concern, on an odd days, porting could take longer
But if you like open ticket with PM support for an update:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
While you are waiting for PM reply, try to login to PM Self-Server every 30 mins.  when you cannot login, that mean porting completed.
shurixp
I still can log in, yes.  My Shaw SIM is in now. I do not have an access landline or an alternative phone.
@shurixp wrote:
I did it via SMS. and received an SMS. Replied YES. It is still not ported after 4-5 hours.
@shurixp   can you still log into My Account?  is your PM sim card still working?
If you already have Shaw sim card in a phone, reboot it once and try to make a call to yourself from a landline
shurixp
I initially received an SMS and replied YES. Waited 3 hours, changed SIM cards, and disposed of the old SIM card. However, the number is still not ported. Shaw support recommended contacting Public Mobile support to do it manually.
HI @shurixp   Contacting support team as the first suggested might not work
Unless in some very special situation, you need to say Yes to the porting request yourself.
I think just contacting support team without understanding this will just waste you more time.
shurixp
@shurixp   why PM has to manually accept the port?  Porting authentication should be done by you with SMS.  PM will send you an SMS and you reply YES within 90 mins
Critical thing is your PM account MUST BE ACTIVE.  I don't think they can exempt that if you are moving to Shaw's
If your account is active but you are not receiving the text , then message PM with this direct link:
https://urlshortner.tiia.ai/Lc9xk8
shurixp
Thank you! Will do.
There usually isn't a need to get it approved manually.  A text message gets sent to your Public Mobile phone/service and you're required to reply to it within 90 minutes.  After doing that, the rest is automatic.
Timer
@shurixp
If you have not received the SMS to authorize the transfer request for your phone number, you’ll need to contact a Customer Support Agent.by Chatbot
or contact to support team by private message CS_Agent
