Points switch from rewards
chrissyseehaver
Just wondering if I maintain my refer a friend monthly reward if I transfer to the points - so if i currently get credit for 3 friends referred, do I maintain the 3 friends referred or do I only get points on new friends referred?
@chrissyseehaver with the new point system, the major loss is the Loyalty rewards.   People can get as many as $5/cycle ($60/year) after their 5th anniversary,  but new points system give you 10 points (=$10) on anniversary regardless your number of years here
Check my comparison post:
https://productioncommunity.publicmobile.ca/t5/Get-Support/is-the-new-public-point-system-better-tha...
walker1
Yeah and don't ever hold a grudge either.
darlicious
@chrissyseehaver
Just to reiterate......
JUST DON'T D0 IT!🛐🤑
@chrissyseehaver...
Here's a bit of reading for you to do before making any drastic change to your account...
https://www.publicmobile.ca/en/bc/get-help/articles/Public-Points-Rewards
walker1
@chrissyseehaver
Don't switch to the point system!
It's worse than the rewards system!
You'll get all points if you switch to point system. No good.
You'll get to keep all your rewards you currently get with your switch.. and you'll just add to that when you refer more friends.
