Plan
Ghazall
I had the Black Friday plan and did not change it( 20GB at 4G Speed, 30-day plan, $20 off(paying 35$ instead of 55$))
but for February, 55$ is deducted!! Do you know why? What should i do? Tx
OlivierR
It shouldnt cancel itself, you can try to contact the customer support and see what happen and maybe get a credit for it you can contact them by sending a private message here https://productioncommunity.publicmobile.ca/t5/user/viewprofilepage/user-id/22437
Ghazall
Thanks but i was wondering why it is canceled? Can it be canceled without a notice? What happened?
OlivierR
You can check your paiment history its under subcription and add on in your account. There's curently a 50GB at 5g unlimited data avaible if you are looking for a better plan
