11-28-2023 07:36 PM
Hi,
can you advise on the full, exhaustive list of phones compatible with Public Mobile's 5G network?
I'm aware of https://www.publicmobile.ca/en/on/get-help/articles/volte and it's not what I'm looking for as I guess there are phones not compatible with VoLTE but still compatible with 5G network.
Will any phone which meets the requirements posted at https://www.publicmobile.ca/en/bc/get-help/articles/check-your-phones-compatibility which are support of 5G network per se and specific frequencies "700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS)" work in PM's 5G network?
Thank you.
11-29-2023 05:59 PM
HI @dest1
basically most 5G phones on the Canadian market are compatible with PM
VoLTE is different, it might not. But big brands phone new in the last 2 years like Samsung, iPhone, Motorola are VoLTE compatible. Someone using Umidigi A13 just reported working as well:
https://productioncommunity.publicmobile.ca/t5/Get-Support/UMIDIGI-A13-Pro-5G/m-p/1099882
