05-23-2023 03:11 PM
Hi! For the past few days I’m unable to dial in and get any calls with my phone number. I have paid for my phone account but it’s still not in service when someone tries to phone me. What gives?
05-23-2023 03:19 PM
Hi @HSMmechanics when did you make the Las payment?
please login My Account using Incognito/private/secret mode again and confirm the account status again
Also, does the phone showing connecting to PM network? Is mobile data or sms working?
05-23-2023 03:18 PM
does texting in and out work? Does your data work?
Try switching your device to 3G only then see if calling works…
05-23-2023 03:17 PM
@HSMmechanics - we are customers like you here trying to help, and have no access to your account.
Have you ported/transferred your number over to Public Mobile? Maybe the port failed.
Or did you issue a chargeback on a card for a charge against public mobile, this will disable your account.
Otherwise, if your My Account or when you call 611 is ACTIVE, then try:
05-23-2023 03:15 PM
@HSMmechanics Try taking SIM card out and re seating it in your phone and reboot the device also you try to reset network settings also and see if that helps , if all else fails you can contact support
Watch for reply top of page to the
Right ( envelope image )
05-23-2023 03:14 PM
@HSMmechanics Have you tried to dial 611 or log into your account just to ensure it's active? You'll want to ensure that your account is active first. Try giving your phone a restart and ensure it's connecting to the PM/Telus network and you have a decent signal. When calling your number do you get voicemail greeting then or out of service message?
05-23-2023 03:14 PM
I don’t have another phone, so that doesn’t help.
05-23-2023 03:13 PM
@HSMmechanics Can you try the SIM card in another phone and see if services work correctly
