Phone not connected
MarieGee
Sim card is in - why does phone not work.  Payment went through
24 REPLIES 24
dust2dust
If this is the first time you've done anything with the phone then sure I guess you could try the reset. But that would normally be the last thing you'd want to do. I hope you haven't used it for much of anything as backups can also be hit and miss. I very much regret doing a reset a while ago over another problem so I would not recommend it. But maybe here...
@MarieGee
try factory resetting the device and then trying the sim card.
  • open settings
  • general management
  • reset
  • factory data reset
  • reset
this erases everything on the device.
@MarieGee...
from what you're reporting, it doesn't sound like an account issue...more like a hardware issue. Either your new phone is gibbled or the PM sim is.The quickest way to determine that is to find an unlocked phone and try the sim in that phone. Alternative is to find a working PM sim, try that working sim in your phone.
MarieGee
yes can log into acct
sim is flush with tray
dust2dust
Yes, can you login to your account?
Are you sure the sim is resting nicely down into the little slot area on the tray? It shouldn't be "above" the tray at a corner or whatever. It should be basically flush with the tray.
As that dealer is reputable, he might be able to help trouble-shoot with you...just to make sure new phone is working properly.
See if he has an unlocked phone handy that you can try your PM sim in.
Hi @MarieGee ... you can open ticket with PM CS agent.  But if they confirm the sim setup is all good , then you really need to find ways to test your phone and sim card
MarieGee
@hTideFnow - neither option available at the moment
MarieGee
yes moved phone number from home phone
Hi @MarieGee no sim card, usually is a device or sim card problem  You can test your sim in another phone?  And you can test another simcard on this phone?
When you recently activated your new PM account...did you also port your number from previous cell network provider ?
MarieGee
when I dial a number - says not hooked to network
Hi@dabr many of her replies like this missing the word IF
and yes, some "member usernames"  have great speed replying but hard to understand
MarieGee
it says no sim card - emergency calls only
DDM69
The usual cut and paste reply from Alexandf…👎🏻
@dust2dust wrote:
@Alexandf- Rebooting the phone might work. Why are you saying it won't?
@dust2dust     My guess would be that there's a word missed by that user which can make all the difference..
@MarieGee- From a full power off, when you turn the phone on, do any messages appear?
dabr
Try rebooting the phone or removing the SIM and back in again after couple of minutes or even a network reset.
Alexandf
@MarieGee
reboot phone not works, open ticket with PM support and ask them to check it
 At https://publicmobile.ca/chatbot.
Start by typing "Submit a ticket", then click "Contact Us", Then click "Other", then click "Click here to submit a ticket
have trouble with Chatbot: Private message CS_Agent
MarieGee
samsung A10e
Hi @MarieGee
yup, still check the device check just in case
https://www.devicecheck.ca/check-status-device-canada/
MarieGee
yes new phone from reputable dealer
dust2dust
iOS? Android?
hairbag1
Have you made sure your phone is unlocked and not blacklisted ?
Can you try that sim in a known unlocked phone.
