08-04-2019 06:02 PM - edited 01-05-2022 06:16 AM
Hi,
My account number is xxxx
3 days ago, I can't make outgoing and receive incoming calls on my phone.
My account is in good status and not sure what has happened. Please help !
Edit by mimmo
KK
08-05-2019 07:26 AM
If you are not on an unlimited plan, buy that $5 add on for 500 minutes. It's the best investment you'll ever make!
08-05-2019 03:58 AM
@kenhu4654 wrote:Hi,
Edit by mimmo
KK
Go in your self serve account. In usage part, if it doesn't say amount of minutes left if on $10 or $15 plan, all minutes are gone. You would need to ask moderators to renew plan early, change plans, or buy add-on for more minutes.
08-04-2019 07:25 PM
Are you on $10 plan?
You can buy 500 minutes for$5 and they don't expire ever, really good deal in my opinion..
You can also ask moderators to renew your plan early but it's a long wait as they are busy.
If you switch to $15 plan now you will get unlimited incoming and snail data, and you can schedule to come back to 10 plan the next cycle.
08-04-2019 06:12 PM
@ChuckYeah wrote:What plan are you on? Any chance you've used up your minutes?
Best to remove your account number. It won't help on this forum but it makes it available to the general public.
08-04-2019 06:11 PM
