07-16-2023 02:12 PM
07-16-2023 06:39 PM
@Comic_Con2024 have you try again? worst case , message support and they can apply it for you:
07-16-2023 02:40 PM
So yes if you were making multiple attempts then just wait the hour and be careful on typing it in and maybe it will work. I think it has been found that the multiple attempts counts for both 611 and the account. Not certain.
07-16-2023 02:35 PM
I got my voucher from Circle K
07-16-2023 02:29 PM
I made a lot of mistakes when I punched in my payment vouchers on 611 called and it will not go through. Online to
07-16-2023 02:28 PM
@Comic_Con2024 where you got the voucher from? has it been over 24 hours?
07-16-2023 02:18 PM
Some vendors have an inexplicable delay in the vouchers becoming usable. Presumably they "settle" their pinpads or whatever overnight or something. Also, you only get a couple chances per hour. Wait another hour and try.
There are preferred voucher vendors that are immediate. There are also online options that are immediate.
07-16-2023 02:17 PM - edited 07-16-2023 02:18 PM
@Comic_Con2024 Some vouchers purchased . Will need to wait 24 hours after you purchased it to load *611
Has it been 24 hours since you Purchased it
