Park phone number, and forward calls to new number?
dsc9
Hi, I'd like to change my current phone number at public mobile. But I expect that many people will try to reach me at my old number. So I'm wondering if I can pay a fee to have my old number parked, and have calls to my old number be redirected to my new number?
Thanks
allendick
In my experience, forwarding cannot be trusted. "Always Forward' changed itself to 'Send to voicemail' on me without warning, so check periodically -- and keep your old SIM.
HI @dsc9
please note while open new account for the new number is an option, there won't be any way for you to switch numbers between the 2 accounts in the future.  PM won't do it
So, when it is time you want to get rid of the old number, the old account will be gone and you will loss your rewards system as well.  That would be a big lost if you re on legacy rewards system
@dsc9  That won’t be possible if you want a new number just create new account with new number put  you current plan down to the $15!plan and forward that old number to new account until your satisfied all your contacts got your new number . And keep that way or cancel it then after some time . But as @hTideGnow  mentioned once you port it out the PM account is closed
HI @dsc9
problem is , once you parked your old number by porting, your  account will be closed
or once you picked a new number ,the old number will be gone
there is no way to keep the number and park somewhere and on the same account  to pick a new number
