Paid the fees But no servive
Melodyxu
I purchased package for new plan, it shows successful in my profile. But still no service, can't call, can't answer, nothing.
Plz help!
HI @Melodyxu
some customers have problem with the service after a plan change., so, it is not uncommon  please submit ticket with CS agent as said above
Melodyxu
It's an old Sim and I used it for 2-3 yrs. I just upgrade my plan to 5G yesterday, and so far still not in service
Melodyxu
It's physical sim Card, I used it for 2-3 yrs
Phil_Adelphus
@Melodyxu   If you still have no service, it may help to know if you are using a Public Mobile physical sim card or an esim.  Is your phone giving you any kind of no service message, SOS, emergency calls only etc?  Is this a new to you phone?
NDesai
@Melodyxu Did you port in your number during activation? If yes, did you reply to a text message to authorize the port in? Porting process can take sometime and you won't have service for a bit until porting is complete.
Sansan
Try to reboot your phone.  If still not successful,  send a message to Public Mobile at the link below for assistance.  They will reply back via message in your community mailbox.
