PM's SMTP Outgoing Server
hlkidd
Hello everyone,
I recently joined Public Mobile and I'm trying to setup my work e-mail on my phone.
What is PM's outgoing SMTP server?  Which port?
Thanks!
10 REPLIES 10
Michael77
I keep learning more and more each day. Thanks. 🙂
I also can't think of any reason to use a Public Mobile SMTP server.  Public Mobile isn't an internet provider, and doesn't issue e-mail addresses to subscribers.  Any use of Public Mobile or Telus's servers for e-mail purposes with be unauthorized and otherwise something that you're not supposed to do.  You would be using someone else's/another company's e-mail servers to relay/redirect your e-mail message communications.  Even the outgoing messages did go through, such relaying would likely fail e-mail security checks and get flagged as spoofing, unsafe, or as spam.
There was a day that even some of  Canada's largest ISPs allowed such a security vulnerability.  It was easy to spoof yourself as being someone else, and then even use the proper servers to send the messages, making the spoofed messages appear more legitimate.  I tried that before as a joke to a friend (example: making it look like friends were sending messages to themselves, etc.).
Grampa
OP must be using BlackBerry?
srlawren
@stonechucker that was my thought, too.  Isn't that relaying, if I remember correctly?  Which I thought pretty much everyone turned off to prevent anyone from using your server to send out spam or worse?
If it gets accepted to send, I'd be really surprised.  Other than text messaging, I wouldn't allow any form of message be sent via the Telus server without some secure form of authorization.
srlawren
@stonechucker although, @canucks4life's accepted solution above makes me thing PM may have outbound SMTP support?  I would still use my work's mail server instead though for work account.
@srlawren, thanks for confirming... thought I was going nuts 🙂
Had to recall my IT Helpdesk work from ages ago.
srlawren
@stonechucker wrote:
Forgive me, but don't you want the information for your work SMTP server?  Why would you need the one for Public Mobile?
@stonechucker agreed 100%
stonechucker
canucks4life
smtp.telus.net port 25 should work fine using cellular data.
