Outgoing message 7723
qiaoshuhong
When I checked my usage history, I found 5-6 outgoing messages to 7723 everyday, anybody knows what this is about?
2 REPLIES 2
When searching 7723 in the Community search box there are quite a few there.
See the solution on this one, and maybe it will help you too:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Reoccurring-Automatic-Outgoing-Text-Messa...
hairbag1
Do you have visual voice mail enabled in Settings ? If so...disable it.
